Remove and replace return inlet faceplate.
Nope, I've done it several times. Obviously, turn the pump off. Take the ring off slowly and keep some hand pressure on the vinyl behind the removed ring. There is (normally) a black oring or ridge of plastic on the ring and the old faceplate will have pushed the vinyl into the matching groove a bit. There shouldn't be any problems.
Another option is to wait and do it when (if) you drain down for winter...
