Thread: Heat pump BTU recommendation for Nova Scotia, Canada
    Jul 2011
    Nova Scotia, Canada
    7
    New pool owner and looking for recommendations from the experts on how many BTU's I need for my 21' AGP (10,400gal). Going to pick up a heat pump over the winter or spring but not sure if a 50k BTU will do or if i need a 100k BTU. looking to run the pool from May to September. Ill list the average temps below for my location and hopefully some in the same area or someone with the same average temps can chime in. The price difference between a 50k and 100k is about $1000 CAD. So if I can get away with a 50K BTU and save the $1000, that would be great. Thanks in advance for any help.
    Average temps for each month:
    May 54F ( Want to open pull mid May or so)
    June 59F
    July 65F
    August 65F
    September 58F (Close pool mid to late Sept)
    21' Sharkline Venture AGP (10,400g)
    Hayward PowerFlo Matrix 1hp pump
    Hayward 21" sand filter (200lbs)
    Hayward 900 auto vacuum
    Fafco Solar Bear 4x20
    Hard plumbed
    Re: Heat pump BTU recommendation for Nova Scotia, Canada
    50 oF is about as low as you would want to go when using a heat pump. The efficiency drops off quickly as the ambient air temperatures fall. Bigger is definitely necessary. 100 K is the minimum that I would suggest.
    Gas would be better if it is available.
    Support the site
    Jul 2011
    Nova Scotia, Canada
    7
    Thanks for the reply. We don't have natural gas unfortunately so that's not an option. We do have propane (stove, hot water, fireplace) but it would be more expensive than electricity according to a calculator I found through this site.
    I was thinking a need around 100k but wasn't sure. My neighbour has a heat pump but he's gone away and I don't wanna be snooping in his yard to see the BTU's. Lol will check with him also when he gets back but he only gets about 2hrs of sun on his pool whereas we get about 8hrs. We also have a solar blanket which is keeping the heat in at night.
    Any others care to chime in?
    Hard plumbed
    Ft Lauderdale, Florida
    1,455
    If your pool is outdoor, DEFINATELY use a solar blanket.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
