Thread: Stenner pump tube replacement
    Jun 2011
    NW Florida
    57
    I have a Stenner pump (45M4) with a blown pump tube (#4). Can anyone recommend a part supplier? Also, I have only been able to find the part available as a 2-pack. Do they need replacing often?
    Mike
    Commercial,100 K, Liquid chlorine, Indoor, Heated to 86 with Jandy Lite 2 gas heater, High-Rate Sand Triton TR-100 filters (3), 7.5 HP pump motor, IG, Plaster.
    Jesus is my Lifeguard!
    Jul 2009
    London and France
    574
    Re: Stenner pump tube replacement
    Can't help specifically with a supplier, I change my tubes every two seasons (domestic), for safety change each year on comercial.
    Some help on this thread:
    http://www.troublefreepool.com/just-...?hilit=simpool
    And specifics on different tubes, Santoprene is the best.
    http://www.uswatersystems.com/shop/p...ance_Guide.pdf
    Maybe Google Santoprene?
    22,543
    US Water Systems is a good place to start.
    As Tea said, they usually last a couple of seasons or more.
    Jun 2011
    NW Florida
    57
    Thanks Bama and Tea
    Make sure when you install the new tubes, they are in the middle of the roller.
    You can get the 5 packs here:
    http://www.lockewell.com/index.php?main ... &cPath=1_6
    Good Luck
    Jun 2011
    NW Florida
    57
    Quote Originally Posted by lockewell
    Good Luck
    Thanks!
