Thread: Borates
    Borates
    Hi all. New to BBB and loving my pool alot more this year thanks to all the great information on here!
    I've looked at the pool calculator, but I wanted some advice on how much borax and muratic acid to add to my pool.
    In ground
    Vinyl liner
    TA 85
    pH 7.6
    CH 204
    FC 4.96
    TC 5.8
    CYA 31 (my reading from pool store was 14 last week. added 6# but have learned from here that it could take a week to have full reading)
    Re: Borates
    Sorry. Its 23K Gallon
    SWG
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Borates
    According to the pool calculator 23000 pool to bring borates to 50:
    17.8 (18) boxes of Borax
    5 Gallons of Muriatic Acid
    If you enter 0 and 50 into the borates section it should give you the number.
    Re: Borates
    So...typically there are no borates currently present in the water???
    Thanks for the advice. I will go add!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Borates
    Quote Originally Posted by calkat
    Nope, none unless you've added them.
