Thread: Adding Chemicals
    Mar 2010
    Spring, TX
    1,082
    Adding Chemicals
    I have a question about adding stuff like bleach, ma, etc, stuff that you add in front of a return jet. I have a booster pump that is used for a polaris cleaner. When I unhook it, and just turn it off it has a very strong stream. It is located in the middle of the pool. Is it ok to use this to pour the chemicals in front of knowing it always has a very strong stream or is it too much. I never have to worry about it not having a strong stream since it is such a short run.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    22,549
    Re: Adding Chemicals
    Any good sized jet of water will work. The purpose of pouring it in front of a return is that it gets mixed fairly quickly.
