Thread: Heliocol HC-50 4x12 replacement panels
    Just outside 12 yr. warranty one panel has sprung a couple of leaks. used repair kit available. Am wondering how feasible diy replacement would be cost wise. Maybe it would just be best to keep repairing with the plugs. Prices have seemed to be outside the affordable range. Can't seem to get a response from Heliocol. Guess its a dealer oriented network designed to exclude the DIY guys like myself. Anyone aware of a source for replacement panels? thanx in advance for those who respond.
    40K Gallon Pool w 1200 Gal Spa on shared equipment, Delta UV System, Raypak Propane 400K BTU Heater, Pentair 120K Heat Pump, Tagelus Sand Filter, 2 x Pentair Intelliflo VS Pumps--- 1 for Main pump and one for spa jets, Booster/ Cleaner Pump
    Re: Heliocol HC-50 4x12 replacement panels
    Addendum: To those of you who wish a nice quick repair without removing entire tube from the system by using repair kit plugs: buy a 1/4 I.D. length of polythylene tubing. Cut out the leaking section. SLEEVE the polyethylene over the two free ends so that there is approx. 1/2 inch coverage of the free ends.. Walla, instant repair. The polyethylene is somewhat rigid and the fit is comfortably tight. After all, no gr8 deal of pressure is coming through those lines anyway. For good measure, if you have a bit of silicone lubricant, coat those two cut ends before insertion into the new sleeve.
    May 2013
    Naples, Florida
    9
    Dave, After speaking with heliocol, you are able to purchase the 4x12 panels at 50% off. Have you called the dealer?
    12k gal, IG, Pebble, Circupool SI45SWG
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You know you are replying to a post from 2011 by a user that has only ever posted 5 messages
