Results 1 to 18 of 18
Thread: Urgent help please. I have washed down paint in my pool
    May 2011
    Miami, FL
    271
    hello
    the outside of my house is getting painted, and so they painted one wall this past Tuesday. A rainstorm shortly followed, and apparently washed a lot of paint into the pool. Naturally, the pool looks hazy, and I cant even see the main drain. I had hoped that on the following morning, the particles would have settled to the bottom, but apparently not.
    What do I do? Shock it? Add chlorine like crazy? Drain it (ouch...)?
    I was told that pool stores sell some type of chemical that will force the cloudiness to the bottom and then I can just vacuum it out. Is that true?
    help please!!!! My pool was crystal clear before the **** rainstorm.
    Thanks
    16,900 gallon inground pool (16x30 with spa bench)
    Sta-rite cartridge filter
    Diamondbrite surface, redone in 2017.
    1.5hp Hayward Super Pump
    Hayward Navigator Pro suction cleaner with V-flex kit
    30,432
    Re: Urgent help please. I have washed down paint in my pool
    As always, the advice here on the forum really requires a set of test results. Anything less than that is just guessing.
    (The test results will, of course, not detect your paint issue but there is no sense trying to resolve the paint if something else is causing the cloudiness....test results may reveal that)
    May 2011
    Miami, FL
    271
    agreed.
    but i dont have a good test kit yet that will give me numbers, and I know for 100% sure that the cream colored haziness is caused by the cream colored paint that is no longer on the wall. The wall looks like The joker's face...horrible. But that's easy to fix - repaint. It's the pool that has me sleepless.
    The wall is about 3 feet away from the pool's edge, and it rained pretty hard on Tuesday.
    30,432
    Chlorine would then be my guess but I don't know how much to tell you to add. That's not much help, I know. Perhaps you could get some test results from a pool store.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Hi, we can help with this issue, but the test results are important. Just take a sample to the local pool store and ask for a test. Don't tell them about the paint and don't buy anything! Post the results here and we will be able to help you determine how much chlorine you need, and if there are any other problems that may complicate the issue.
    Love TFP? Become a
    TFP Supporter!
    Butterfly's Avatar
    South Carolina
    10,045
    What kind of paint?
    Shocking should take care of it, but might take a while.
    You could use an enzyme product that is specially made to clear pools that have been fouled by large quantities of paint, oil, etc.
    You're done SLAMing when:
    May 2011
    Miami, FL
    271
    i pressume it to be exterior latex. great ideas btw..thank you
    May 2011
    Miami, FL
    271
    i can ask the store for the results? they dont print anything out and usually jut turn around and tell me fine or add this or that.
    I think pinch a penny prints something out, so I will go there.
    Jul 2011
    Central Califorina
    208
    Ouch, paint in the pool. Nightmare. The only thing scarier than that is pool store testing results. I would think some enzyme product would help gather the paint but chlorine will be needed.
    How much? Who knows without accurate CYA results. The amount of CYA in your pool will determine how much chlorine you need. When I tested my pool store testing they told me my CYA was 30 ppm when I know it was 60 ppm. If you get similar testing results you would not be able to properly shock your pool and clear it quickly.
    Please do yourself and your pool a favor buy a good test kit now. Maintaining a $30,000 pool without a test kit is like driving a car without any gauges or instrumentation, never checking the oil or fluids and taking the word of what jiffy lube tells you what needs to be done to your $30,000 car.
    Get in tune with and take control of your pool now. All the info you need is on this site and with a proper test kit we would be happy to help.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by BBBliever
    That is a great way or putting it! And for those of us who bought a used car at a good low price, we still don't want to be stuck on the road somewhere without warning, so it makes sense for us too!
    Sep 2009
    Greentown, IN
    914
    [quote:39tnpl0o]
    That is a great way or putting it! And for those of us who bought a used car at a good low price, we still don't want to be stuck on the road somewhere without warning, so it makes sense for us too![/quote:39tnpl0o]
    I agree!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    22,553
    What model filter do you have?
    I'd start out by running the pump 24 hours a day. You could also add a very little DE to the filter and that'll help clean the water. However it may ruin your cartridge, but the paint may do that anyway.
    24' x 52" Round AGP. 2hp/Ľhp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May 2011
    Miami, FL
    271
    it's a tall cartridge type. I dont have the model handy with me. What is DE?
    Jun 2011
    NW Florida
    57
    D.E. = diatomaceous earth
    Do you know the cost of draining and filling your pool + chemicals?
    Commercial,100 K, Liquid chlorine, Indoor, Heated to 86 with Jandy Lite 2 gas heater, High-Rate Sand Triton TR-100 filters (3), 7.5 HP pump motor, IG, Plaster.
    Jesus is my Lifeguard!
    Mar 2007
    San Rafael, CA USA
    12,082
    I would not add DE to the cartridge filter. If you run the pump 24/7 and do not see any clearing, then the paint may be forming a suspension in the water (like milk) in which case you'd need to use a clarifier such as GLB® Clear Blue® or Natural Chemistry® Clear™ (or Natural Chemistry® Clear and Perfect™ but you have to be careful to not overdose). Since you have a cartridge filter, then I doubt you have a way to vacuum-to-waste in which case I would not use a flocculant (hence, my recommendation of using a clarifier instead). This is one of those rare times where a clarifier can be useful.
    The recommendation of enzymes such as Natural Chemistry® Pool First Aid™ is also good and could clear the pool without need for the clarifier so you could try that first.
    May 2011
    Miami, FL
    271
    thank you all for your quick help. I took my water to Pinch-a-Penny, and the chemicals looked fine.
    TC 3
    FC 3
    TA 120
    Calcium hardness 260
    Stabilizer 80
    They recommended that I pour half a bottle of Pool First Aid, and that I run the pump a lot. Since the cartridge will get saturated, they suggested I clean it with a degreaser various times as I run the pump.
    I poured the first aid, and I see some clarity, but I have not had a chance to clean the filter due to thunderstorms.
    Now. If my paint is not oil based, will the First aid--an oil cleaner, really work?
    Again, thanks to all.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes it should still work. Oil-based and water-based paints are both organics just with different solubility (in mineral spirits vs. water, respectively). Pool First Aid should help and it sounds like it is already helping.
    Jun 2011
    NW Florida
    57
    Quote Originally Posted by nabril15
    TC 3
    FC 3
    TA 120
    Stabilizer 80
    The chlorine/CYA chart gives these numbers for your 80 ppm stabilizer:
    FC min = 6ppm, target = 9ppm, shock = 31ppm
