Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Milky substance comes out of booster pump jet when running
    Jul 2011
    Huntsville, AL
    96
    Every time I turn on my booster pump to run my polaris a milky substance comes out. It clouds up the pool. Any ideas on what it may be.
    18x36 IG Vinyl 23,000 gal, AO Smith 48Y 1hp pump, Jacuzzi Laser Sand Filter 250L, T104R, K2006, Polaris 280
    South Central NJ
    3,192
    Re: Milky substance comes out of booster pump jet when runni
    Air? DE?
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2011
    Huntsville, AL
    96
    Its a sand filter. I'm sure its not air. It actually clouds up the water.
    Jul 2011
    Huntsville, AL
    96
    Anyone?
    30,432
    What do your pool water tests look like?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    94supratt,
    I would keep this in one post for now. Are you saying the cloudy water you had in the other thread only occurs when the pump jet is running?
    Duraleigh see: http://www.troublefreepool.com/water-cloudy-t37524.html
    If your sand filter has a multiport valve with "Backwash" "Filter" "Waste" Etc. the spider gasket has failed. Revove the very top of your filter housing with the handle on it and inspect the gasket. Mine was doing the very same thing 2 weeks ago,
    13,600 gallon AG pool
    Cartridge filter
    1.5 HP Waterway pump model number SD151N11CC
    Jul 2011
    Huntsville, AL
    96
    Quote Originally Posted by linen
    94supratt,
    Yes. I rarely run my Polaris due to this. My water can be crystal clear and as soon as I turn on my Polaris is looks like someone is pumping milk through my line that powers the Polaris. I might take a video to show.
    Jul 2011
    Huntsville, AL
    96
    Quote Originally Posted by gbrent
    I will try that ASAP! Thanks!
    edit-Uuggghh. Looks like the spider gasket is not replaceable. I have a Jacuzzi Laser 250L. I have to buy the item assembly.
    http://www.poolforum.com/pf2/showthread ... lve-Gasket
    also....Why would it only get cloudy when running the Polaris if the gasket failed? The multiport is always in use. I'm confused.
    Jul 2011
    Huntsville, AL
    96
    Here is a picture of what it looks like 5-10 seconds after turning on my Polaris.[attachment=0:2g3putuh]pool.jpg[/attachment:2g3putuh]
    FC - 6.0
    CC - 0.5
    PH - 7.1
    TA - 70
    CH - 40
    CYA 45-50
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Do you use any powdered chemicals in your pool?
    Where is the milky water coming out? The Polaris port or the cleaner itself?
    Jul 2011
    Huntsville, AL
    96
    I use the bbb method. Its coming from the wall return that the polaris is on.
    22,553
    You don't pour acid in your skimmer do you?
    What happens if you don't have the cleaner hooked up to the return? Does it still emit the cloud?
    Is that coming out of the regulator valve?
    Jul 2011
    Huntsville, AL
    96
    I dissolved Cyanuric acid in panty hose to the skimmer.
    No cloud when the Polaris isn't plugged in. Might be something VERY faint coming up when it is off.
    22,553
    Is there air in the main pump basket when it's doing it?
    Jul 2011
    Huntsville, AL
    96
    A little bit, there are A TON of air bubbles coming out of the returns. Oddly enough only the line that the Polaris is hooked up to looks milky when it is on.
    22,553
    Stop those bubbles in the pump basket and I'll bet you stop the clouding.
    Jul 2011
    Huntsville, AL
    96
    I see a leak at the top of fitting that screws into the top of the pump. That is the suction side though isn't it.
    SW Indiana
    9,199
    Quote Originally Posted by 94SupraTT
    Sent from my SCH-I500 using Tapatalk
    Normally the outlet is on the top. You are looking for a suction side leak which lets air into the system. You usually won't see water coming out of a suction side leak except right as you turn the pump off.
  20. Back To Top    #20
    Jul 2011
    Huntsville, AL
    96
    Quote Originally Posted by JohnT
    I'll keep looking. Its frustrating. That said I know my spider gasket is bad in my pump. Could that cause a suction leak?
