Thread: Twist Lock plugs
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Twist Lock plugs
    After some reading tonight, I understand the nature of twist lock plugs, which tend to come on SOME of the pool pumps. With these types of plugs, I assume there comes some additional advantage. However, I wasn't able to really find any information regarding this potential advantage. So, does anyone know why I would want this cord instead of a regular one?
    24' X 54" Sharkline Matrix AGP ~ 15,200 gallon
    1.5 HP Dynamo Dual Speed ran 24/7 at low speed w/250lb. SD60 Pentair Sand Filter
    Plumbed with PVC - buried.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Twist Lock plugs
    It is a code requirement if the pump receptacle is between 6-10 feet from the "permanently installed pool".
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Quote Originally Posted by linen
    Ok. Thanks for the info. So, if the receptacle is less than 6 ft, or more than 10ft. it's not required. Anything inside of that calls for a twist-lock plug? Is this a trip hazard thing?
    My situation is that the receptacle will be 15-20 feet away from the pool, but the pump will be like 3 ft. away from the receptacle. So I have to ask - does the code assume that the filter/pump will be next to the pool? In other words, should the code rather be stated, "If the pump receptacle is between 6-10 ft. from the pump, a twist lock cord is required." ?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Twist locks don't come unplugged by mistake. That's also why you find them on RVs, shore power for boats, and on a lot of construction generators and extension cords.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by moze229
    I believe the code states the cord can be no longer than 3 ft long. The 6-10 feet refers specifically to the distance from the pool to the receptacle. At a distance of greater than 10 feet, you do not have to have twist lock. I am not totally sure about this, but I think if connection can not be made with a 3ft or less cord, the pump must be hardwired, conduit, etc...
    Code does not allow for the receptacle to be any closer to the pool than 6 feet.
    Again, this is for a permanently installed pool. Also, I am not a code expert, just a diy.
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Ok - so I have nothing to worry about then as far as code. The pump will be located ~3' from the receptacle and the plumbing will run about 15-20 ft. out to the pool. Thanks all for the clarification!
