Thread: Noob with IGP and SWG
    Hello,
    Pulling trigger on pool purchase tomorrow with hopes to have all in by first week in September. First off I am a minimalist and have a SPA that I only use baking soda, chlorox and Nature2. Perfect water. With my new pool (18x36 vinyl), I will have a Hayward Aqua Plus and T-Cell-15 as my system. Taking the minimalist approach to the pool, what else should I begin my search for in regards to chemicals and stock up in prep for my install and use pre-close and next season?
    Ted
    South Central NJ
    3,192
    Re: Noob with IGP and SWG
    Muriatic Acid, Clorox, CYA, TF-100 or K-2006 test kit, safety cover, blow through extension or Ultra Gizmo for each skimmer, appropriately sized winter plugs for each return, pool salt.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks Scott. For my size pool, what wry of those products should be on hand? is there a shelf life on any of it that should be considered?
    Thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Since typically you don't switch out water in a pool, say away from the Nature2 for the pool. If interested use the google search at bottom of page and google Nature2.
    By the way, I tend to be a minimalist as well. Only liquid chlorine/bleach, MA, CYA, and borates in my hot tub. Ohhh and water and heat and people
