Thread: CYA test help
    Jul 2011
    Canton, MI
    47
    CYA test help
    I have the TF-100 test kit, and my label fell off of the CYA dropper bottle. Can anybody that has the same test kit measure how far from the bottom of the bottle the label starts? Thanks for your help!
    17,500 gallons, Vinyl, Above ground, Hayward Sand filter, Hayward 1.5hp pump
    Re: CYA test help
    The label is 1" high and the top edge of it is even with top edge of the fat part of the bottle.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    Mar 2009
    Huntsville, AL
    156
    Re: CYA test help
    I think the reagent is a 1 to 1 mix with the pool water. So you should be able to fill the bottle to the normal level with water and pour it into one of the graduated cylinders to see how much of the solution you need. Dump half of it out and put the remaining half back in the bottle and that is where the the bottom of label should be. But someone should be along shortly with a measurement...
    Edit: I guess I type slow!
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    30,421
    Re: CYA test help
    Yeah, however you figure it, it should be a 50/50 mix of pool water and R-0013.
    Please check your PM's
    Jul 2011
    Canton, MI
    47
    Re: CYA test help
    Ok, thanks for everybody's help!
