Results 1 to 7 of 7
Thread: Motor Removal
    Motor Removal
    We have had our pool for one year and this is our first pool. It is a 15x26 Morada with a Waterway Pro Clean Filter and we love it. Today, however we started hearing a buzz from the pump motor which might be a bearing although I suppose it could be the impeller. In looking at the motor mounting they have pins holding the motor to the base. How do I remove those pins? Thanks for you help.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Motor Removal
    Welcome to TFP!!
    There are so many different set ups I'm not sure I remember yours, can you post a pic or 2?
    Luv& Luk
    -Ted
    Re: Motor Removal
    This is our filter
    Re: Motor Removal
    ...and I appreciate any help...this site has lots of info for the newbie owner...
    22,549
    Re: Motor Removal
    Are you sure they're not Carriage bolts you could remove the nut from the bottom?
    If they are pins, you'll have to drill them out.
    Re: Motor Removal
    No they are called snap pins...pictured below.
    Mar 2007
    4,160
    Re: Motor Removal
    Thanks for the pics
    You should be able to pry them out with a flat-head screwdriver. You might need 2, 1 on each side, and a fulcrum near the pin to maximize leverage, but they ought 'pop' out.
    Luv& Luk
    -Ted
