Thread: FAS-DPD testing with bromine
    Mar 2007
    Coastalish 'down easter'
    4,160
    Chemgeek wrote
    Note that the test is measuring Total Bromine and there is no need for the R-0003 reagent. Combined Bromine is automatically measured in the first part of the test since monobromamine is in equilibrium with a more reactive monobromammonium ion that reacts with the dye in the test. It is this reactivity that makes the combined bromine still effective as a disinfectant (though monobromamine can smell if it gets high enough in concentration).
    I've been using my TF100 all season on our indoor pool (not spa) and usually have to add another drop of the R 0871 after adding the R0003, so I include the last drop into my total bromine. I almost always get a little pink from adding the 5 drops of R0003.
    Am I doing something wrong to get a result out of the R0003?
    Luv& Luk
    -Ted
    AClogston's Avatar
    Mar 2011
    Lincoln, NH
    61
    Re: FAS-DPD testing with bromine
    Do you use MPS shock in this pool?
    MPS will give a false high CC reading. I had to buy the special Taylor FAS-DPD kit because of this.
    -Alex
    Outdoor Chlorine Pool/Spa (~100' from pump room):(35,000gal IG, plaster, 2 Triton TR-140 sand filters, 2 2HP pumps),(1,200gal IG, plaster, Triton TR-140, 2.5HP pump [circ.], 2 2HP pumps [jets])
    Indoor Bromine Pool/Spa:(24,000gal, plaster, Triton TR-100, 1.5HP SVRS-equipped pump),(3,200gal w/ 3 waterfalls, plaster, Sta-Rite System 3 cartridge filter, 3HP pump [circ.], 3HP pump [jets])
    Mar 2007
    4,160
    Hey Al
    As a general rule, I don't shock my pools - because I don't have to
    However, my predecessor used to use it, last year - would it stay in the water (70% changed to start the pool this spring) that long?? [also, sometimes I don't get the cc (cb) reading]
    Thanks for all replies
    Luv& Luk
    -Ted
    Montreal Canada
    326
    What you're seeing is combined chlorine - some formulations of bromine include chlorine, first the chlorine sacrifices itself to oxidize the bromide ions into hypobromous acid. Then whatever chlorine is left combines with any organics and thus reacts with the R-0003 as combined chlorine. Combined bromine and free bromine have similar oxidizing capabilities that why you test for "total bromine".
    Mar 2007
    San Rafael, CA USA
    12,082
    It's also possible for it to be an organic combined bromine (rather than the inorganic monobromamine) in which case I wouldn't count that as far as being bromine that you want since it is probably not a disinfectant. Unless that was rather high, I wouldn't worry about it.
    Mar 2007
    4,160
    Thanks guys!
    Sorry for the delay but.. things have been a little crazy at work the past couple of weeks - I've had to take on responsibilities that aren't in my job description (haven't we all, at one point or another )
    Again, THANK YOU!!
    Luv& Luk
    -Ted
