Results 1 to 9 of 9
Thread: Home Depot 15% Acid
    mas985's Avatar
    Pleasanton, CA
    11,741
    Home Depot 15% Acid
    I didn't realize until I was having trouble droping the PH in my pool that Home Depot had changed from 29% to 15% acid in our area. However, they did not change the price which really ****** me off. Lowe's still has the 29% kem-tech. From now on, I will be looking at the labels a bit closer.
    Just wanted to see if that was the case in other parts of the country.
    Mark
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Mark,
    Great point. I will check my home away from home this weekend and respond in kind. Thanks for giving me a reason to go to Lowe's. I am sure my wife will not be happy with you.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    30,431
    Mark, good "heads up"
    HD had stopped carrying acid....at least in Raleigh. Probably so they could sell out the old and replace with the weaker strength.
    Same here in AZ. Kem-Tech is now 15%, so be sure to read the label.
    Here they also raised the price for 1/2 the strength.
    Cliff s
    Guest
    Since 10-15% muriatic acid is often used to clean concrete surfaces that is probably why they are carryig the lower concentration at the Hardware 'big box' stores. It could also be a safety issue. This is why Walmart and some other large retail chains now only sell the 48% cal hypo!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Perhaps, but they sell it in the pool section with the other chemicals so I assume it is for PH balancing.
    Mark
    TexasGirl's Avatar
    Central Texas
    95
    Our local Lowe's and Home Depot are still selling this stuff. Just bought a 2-pack this week:
    Debbie
    My Home Depot sells the 31% as in Texasgirl's post. However, it costs $9.97 for 2 gals and my local pool store sells the same % for $4.33 a gal. Much cheaper at the pool store. This shows that is important to compare apples to apples when shopping. Also my pool store sells 10.5% chlorine at $4.04 for 2.5 gals and another pool supply sells at $3.50 for 2.5 gal of 10% chlorine. Much cheaper than Home Depot's 4 gallons of 10% for $9.97.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Enid, Oklahoma
    53
    I buy 31% acid at a local farm supply store called Atwoods. I'm sure it could be found at other farm stores like Tractor Supply. It is always much cheaper than HD and Lowe's. The only problem is if you buy too much at once the store clerks might think you are running a meth lab.
    20K IG Fiberglass, 3/4 hp Sand, Hayward ColorLogic
