Thread: Light Green Cloudy Water
    We went on a weekend vacation, forgot alll about the solar cover, temps reached 110 heat index and I haven't been able to recover since. The water was murky green and I've shocked/treated/cleaned everyday since but it still doesn't have the clarity that it used to. Any suggestions? Chlorine levels and pH levels all normal...
    19,000 gal IG pool, carthridge, Intelliflo pump, in floor cleaning heads, EasyTouch 4 control panel, SWG, mini pebble.
    Gilbert, AZ
    Re: Light Green Cloudy Water
    Please post a complete set of water test results. Saying "normal" really doesn't tell us anything. You should also read the article in Pool School on how to shock your pool. Shocking is an ongoing process, not something you do each day.
    Is the filter running 24/7? Pressure OK?
