Thread: CompuPool Replacement Salt Cell
    Hey guys,
    I have a Autopilot salt water pool system with a "SuperCell SC-48". I am getting a message saying "Warning - Low Amps, Cell?" and "check cell". I have looked in the cell and see no scales on metal. My chlorine level has dropped recently and it seems to not be producing any chlorine. I am thinking this cell has to be at least 3-5 years old and the pool was not taken care of at all before I purchased the home. Here are my questions:
    Should I replace the cell?
    Should I replace the power cord while Im at it?
    If so, is the CompuPool Replacement Cell comparable to the Autopilot brand? It is much cheaper and would be easier to bite off.
    Thanks guys
    -Josh
    Re: CompuPool Replacement Salt Cell
    Welcome to TFP!
    We have heard a few negatives about the CompuPool replacement cells, specifically the largest one, and a couple of positives. But it is too early to tell if problems are unusual or common.
    What are your amps and volts reading when you do a test pool pilot while the cell is on? Also, when you look at the cell plates, do any of the corners look worn away, or are they all the same?
