Results 1 to 8 of 8
Thread: White Deposit in grout lines next to waterfall
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    I have a white deposit forming in the grout lines only along side the waterfall. This is only happening were there is no standing or flowing water but area is wet from waterfall splash. It is only in grout line and nit on flagstone. It runs down out o grout onto tile.
    I cleaned it off one by spraying with diluted muratic. It quickly came back.
    What is causing it? Any way to stop it?
    Test numbers:
    fc: 6
    Ph: 7.6 (about to add acid to bring to 7.4)
    ta: 60 (to low, I'm going to add baking soda)
    ch: 290 (on the hard side but not too high?)
    Cya: 60
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: White Deposit in grout lines next to waterfall
    I should add it looks to me like the deposit is leaching out of grout instead of being deposited by pool water but I'm not certain of that.
    a picture here would be great I'll try to pst one later today.
    Jandy 2 speed pump
    That is called inflorescence. Yes, it is leaching out. I've been told that sealing the stones or maybe the grout is needed.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    I'm not familiar with inflorescence - just typed it into google and all results have to do with flowers?
    This is the first time I've posted pics. Lets see if they show up.........
    https://picasaweb.google.com/1121019057 ... 2587595234
    https://picasaweb.google.com/1121019057 ... 4299995298
    https://picasaweb.google.com/1121019057 ... 5845395282
    Jandy 2 speed pump
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by texasdad
    Nothing to see here. Move along....
    BTW, it's probably efflorescence.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Ha, my horticulture background apparently. Well, maybe eff.... whatever
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    efflorescence - just tried that in google can got responses that make more sense.
    That is whats going on here...... now what to do about it? Sealing is the best option;
    Any suggestions on what sealer to use on the grout and flagstone. I guess the same stuff people with salt water pools use?
    Jandy 2 speed pump
    30,411
    Whatever type sealer you use, it may or may not work. It is difficult to get it to stop since it is coming from behind the grout and will typically lift or or "push out" sealer. That said, it is about your only option so give it a try. Home depot sells an expensive grout sealer who's name I can't remember but comes in a dark green plastic bottle.
    You could just clean it off with acid and see if it continues but I think I would celan it and then seal it and cross my fingers.
