Aquarite Flow Switch and Fuse Issues
Aug 11, 2011
4
I keep blowing fuses. Now I'm not sure I have the right fuse in there. What fuse do I use for Goldline Aquarite SWG?
Also, my dog chewed the wire to the flow switch awhile back. I was able to splice it and all has been well until recently, when it shows "No Flow" and my water is green. Shocking now.
The switch is installed correctly and looks OK (no pieces missing inside). When I twist the two wires that lead to the switch together, shouldn't that give me a green flow light? I want to see if it is something else before I replace the flow switch.
Also, in case I do need to replace it, where can I get one cheap?
Thank you!
