Thread: cyanuric acid dissapation
    May 2011
    4
    had a customer that opened his pool this spring and the cyanuric acid level was zero and had a chlorine demand. When pool was closed last fall his cyanuric acid level was75ppm. What happened over the winter?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Re: cyanuric acid dissapation
    Under certain circumstances bacteria can convert CYA to ammonia over the offseason. The answer to the extreme chlorine demand is a lengthy shock cycle, until the ammonia is gone.
    post88242.html#p88242
