Thread: AquaRite Reading 0 ppm salt
    My AquaRite was reading 3000 ppm salt. After a power outage, it is now reading 0 ppm. I have an extra cell and it also reads 0 ppm. Do I need a new PCB or is there a simpler fix? Thanks
    22,550
    Re: AquaRite Reading 0 ppm salt
    Have you checked all the fuses?
    Have you checked this topic to see if that's your problem?
    I check the main fuse but did not see any others...
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    A nearby lightning strike (which could cause a power outage) could cause one of your sensitive pieces of hardware to 'freak out' and no longer 'play nice'.
    Try turning off the power to it for ~ 1 min. and see if it comes back on line. If it doesn't - call in the service company.
    If it's lightning, your insurance may cover this
    Luv& Luk
    -Ted
