Results 1 to 16 of 16
Thread: How Much Work To Get A Sand Filter Online?
    Jul 2007
    Hillsborough, NC
    525
    My current pool is an Intex AG. The original pump that came with the pool is dying a slow and painful death after 5 seasons. I have a pump and sand filter for the much larger AG pool that I will set up next spring. It is 3ish weeks till Labor Day, I usually take the pool down around then. What would I need to do to the sand filter to get it online and hooked to this pool? I am trying to decide if it is worth only using it for 3 weeks.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Jun 2011
    Cape Girardeau, Mo
    125
    Re: How Much Work To Get A Sand Filter Online?
    Is the sand filter you have an Intex sand filter if so they come with adapters and you could have it up and running in an hour or so.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Jul 2007
    Hillsborough, NC
    525
    Nope. The pump is a Hayward. I forget the model number. I was just wondering how complicated the plumbing is or can I just more or less set the thing up in place of the old pump, connect it and go? Obviously I would have to find adapters, etc. The filter has been sitting for a while - do I need to backwash or anything?
    22,548
    It should be easy to set up, but if you plan on moving it you'll have to take all the sand out of it and I don't know if you want to go to that much trouble for three weeks.
    Jul 2007
    Hillsborough, NC
    525
    I am not being a smart-***, why do I need to take the sand out? If it is because of weight I moved it to my house when I bought it with the sand in it, so I expect I can move it across the yard with the sand still in it. If it is because the sand needs to be repacked or something, then you are correct.
    Jul 2011
    Central Califorina
    208
    I'm not being a smart ***** either but let's hope you moved it VERY carefully. There are alot of delicate parts within the filter that the sifting of hundreds of pounds of sand can damage. IF you got lucky and it works to be safe it is recommend to remove the sand when transporting in the future.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    Jul 2007
    Hillsborough, NC
    525
    Hmm... well I put it in the back of a truck, then took it out again. I didn't drop it, but I also didn't exactly handle it with kid gloves. I don't know what the previous owner did with it. I thought the filter was just a big plastic container with sand in it. What is the best way to open it and check it?
    Jul 2011
    Central Califorina
    208
    Sounds like you transported it fine. What the prior owner did???? Most damage to laterals (interal componets) occur when people try to roll the plastic jug across a yard. This will likely crack the laterals. Best way to see if it works is to get it online. I would try to get it up this season so you will know if it needs repairs. Also try to find a online manual for it so you can educate yourself about it.
    Taylor K-2006
    22,548
    It's the breaking of the internals that is the concern. Those things are delicate and they sit in sand so a shift will break laterals, break stand pipe, and possibly break the neck of the multiport valve. Do you feel lucky?
    Jul 2007
    Hillsborough, NC
    525
    Ok I will hook it up and test it. As far as the manual goes, the pump motor is a hayward, I can find the model # on it. I don't recall seeing a label on the filter. Would the pump and filter have been sold as a unit?
    22,548
    Porbably so. That's the way they usually sell them.
    Jul 2011
    Central Califorina
    208
    Also, when hooking up the non intex pump you will have to find a way to adapt the 1.25 inch fitting to 1.5 inch. I would recommend ditching the intex intake/return and installing standard Hayward fittings. Then hard plumb or use flex pvc. This will give you a real pump filter without the problems associated with intex.
    Taylor K-2006
    Jul 2007
    Hillsborough, NC
    525
    I actually have the intake and return to the pool plumbed through PVC ball valves so I can isolate the pump. I should be able to hook those to the new pump without too much trouble.
    Jul 2011
    Central Califorina
    208
    Only other issue would be the age of the sand. If you think it might be have been used for more than five years I would get new sand, about $10 for 50 LBS. New sand will have sharper edges and filter better.
    Taylor K-2006
    22,548
    That's the conventional wisdom but it really doesn't pan out. There have been a couple of posts where people have put old sand and new sand under a microscope and you can't tell which is which. They look the same.
    Jul 2007
    Hillsborough, NC
    525
    Well I am gonna pick up a replacement small pump tomorrow. Found one for 20 bucks and I was informed there was swimming with friends planned for Saturday. I won't have time to get the bigger pump up and running before Sunday or Monday so....
    thanks anyway, there is some good info here for whenever I do get the big pump hooked up.
