Thread: My pool is losing an inch of water a day
    I recently had my pool re-plastered and re-tiled. Since the pool has been finished I have needed to fill my pool every day (I am losing about an inch a day). Also, the pool deck is cracking, raising and sloping. I don't know if these have any thing to do with eachother, but I am very worried. Does anyone have any ideas or suggestions as to what I should do?
    17000 gallons
    DE filter
    IG
    Diamond Brite plaster
    May 2009
    Youngsville NC
    395
    Re: My pool is losing an inch of water a day
    Put an automatic filler on it. Mine looses that inch plus daily - especially when it's over 90 .
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Hi, welcome to TFP! What general geographic area are you located in? Also, do you have a multi-port valve with a waste line?
    You can do the bucket test to check for leak vs evaporation. Take a bucket and fill it about 1/2 full of pool water. Mark the water line inside the bucket with a sharpie. Set the bucket on the steps of the pool so it is partially in the water and mark the pool water line on the outside of the bucket. Turn off the pump and all water features and let it sit about 24 hours. After 24 hours take a sharpie and mark the new water levels inside and outside of the bucket. If the water loss is evaporation then the water loss inside and outside the bucket should be about the same. If it is a leak then the difference between the water levels on the outside of the bucket should be wider than the difference between levels on the inside of the bucket.
    If you can post a picture of the pool that may help us figure out what is happening to your pool.
    Love TFP? Become a
    TFP Supporter!
    I don't know an inch a day seems like a lot to me. It's very hot here too but we have been getting enough rain to not have to fill the last few weeks. Even when we had the extended drought earlier this year I don't think I lost an inch a day. I did loose enough to complain about but I don't think it was an inch a day.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    30,421
    An inch each day is excessive an indicates a leak. It may well be connected with the lifting and cracking of your deck.
    Generally, finding and fixing the leak is not a job for an amateur (if the lifting deck has caused the issue.)
    With the pump off, see if you can have some luck with a syringe and some red dye injected in the skimmer. If the leak is in the underground pipes, it is possible you will see the dye being sucked into the pipe, albeit very slowly.
    May 2011
    Montgomery, TX
    176
    imo if you're losing more than 1/2" per day you have a leak.
