Results 1 to 7 of 7
Thread: Issue when turning off pump...water shoots out skimmer
    Jul 2011
    Huntsville, AL
    96
    According to my pressure gauge on my filter I don't need to backwash. However, the last time I shut off my pump water shot out of skimmer and caused the skimmer cover to fly off and the basket was no longer sitting flush. Any idea what the cause may be?
    18x36 IG Vinyl 23,000 gal, AO Smith 48Y 1hp pump, Jacuzzi Laser Sand Filter 250L, T104R, K2006, Polaris 280
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Issue when turning off pump...water shoots out skimmer
    Sounds like you may have air trapped in the filter. Is there an air bleed valve you can open?
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    Huntsville, AL
    96
    Quote Originally Posted by zea3
    Not that I have seen.
    30,432
    I agree with zea#, You have air trapped inside your filter. What you will need to do if the air persists is to trace down the air leak. It is on the suction side of your system. The pump is sucking in air and forcing it in to the top of the filter and building up pressure. When the pump is turned off, the compressed air in the filter forces the water back through the system and out the skimmer
    If you have no relief valve, is air coming out of the returns...pump running?
    22,553
    I typed a big long post for this and wouldn't you know it. My wireless modem died!
    Anyway, I agree that you are getting air in the system.
    Check the skimmer weir to make sure it operates freely.
    Check the water level to make sure it's about 3/4ths the way up the skimmer face.
    Check, clean and lube the pump basket o-ring and sealing surface.
    Check and reseal the pump basket drain plug(s). There may be more than one.
    Jul 2011
    Huntsville, AL
    96
    I haven't seen any bubbles. That said I have my return eyeballs pointed up so I'll try pointing them straight to see if I see any bubbles.
    My skimmer doens't have a weir. The water level is about 1/2 up the skimmer. What should I lube the pump basket o-ring with? Also, what should I reseal the pump basket drain plug with.
    22,553
    Start by looking in your skimmer when the pump is running and see if it's creating a vortex sucking in air once in a while. You may have to watch it a while before you see any.
    Then clean the pump basket o-ring and sealing surface and lube the o-ring with silicon pool lube. Jacks is a good one but whatever the pool store has will work.
