Results 1 to 13 of 13
Thread: Channel Drain covered in shotcrete?
    When the contractor's shot the pool they covered the channel drain with shotcrete. You can see the outline of the drain, but it is completely covered. Is this normal? Also if you have an in floor cleaning system(PV3), do you need wall returns as well? Pictures posted soon.
    Aug 2007
    near the swamp
    806
    Re: Channel Drain covered in shotcrete?
    they usually cover it in cloth or some tape or so and shoot around and over it, they will remove it before they plaster it
    or so I hope they do
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    It's a good idea to have a couple/ few wall returns with the in-floor system. They'll provide top circulation so that floating debris ends up in the skimmers.
    Luv& Luk
    -Ted
    This is how the channel drain looks currently after being sprayed over with shotcrete. Also there are no returns only the in floor system.
    nutjob's Avatar
    May 2011
    Dallas
    109
    Mine looked pretty much the same after shotcrete (gunite in my case) but it turned out all right. Apparently there's a built-in cover that's removed at plastering. See pics at http://gallery.me.com/kellysean1#100034
    My pool has an in-floor system but also two returns for the two skimmers. I'm no expert but having both top & bottom cleaning systems is probably a good thing.
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    22,553
    My personal opinion is that I'd have them add at least 2 wall returns. Now's the time to do it, rather than wishing later that you'd had them. All they have to do at this stage of the game is knock a couple of holes in the walls. It's a whole nuther ball game later.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    nutjob,
    Wish I would have seen your pool before I started mine. I would have stole some ideas. What a BEAUTIFUL pool. It certainly did work out!!!
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    nutjob's Avatar
    May 2011
    Dallas
    109
    Quote Originally Posted by XsAllOverIt
    nutjob,
    Awww, you know how to make a guy blush!
    (Kahunawahoo: keep us posted on the progress.)
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by nutjob
    ... My pool has an in-floor system but also two returns for the two skimmers. I'm no expert but having both top & bottom cleaning systems is probably a good thing.
    My personal opinion is that I'd have them add at least 2 wall returns....
    My only 3 returns are in the floor (and they're not even an in-floor cleaning system) with a main drain and 2 skimmers. I've never even considered, in 15 years of owning this pool, that a couple of wall returns would improve anything.
    I'm sure Nutjob & Bama have legit reasons for their opinions. I'm no expert, just another country heard from.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Thanks for the responses, drain was protected with a cover and seems to be a non-issue now. Glad to hear others with in floor cleaning systems don't necessarily have wall returns too. The pool seems to be coming along, albeit slowly. Here are some recent shots of the tile going in.
    Do you know what brand of in-floor cleaner you have? Paramount normally designs the system after getting the plans from the builder and they include wall returns provide top to bottom circulation.
    13k gallon IG plaster, DE filter, 3/4hp Pump
    It is the PV3, by Paramount.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That is going to be a very nice pool. Hope to see some progress real soon. Thanks for posting.
    Essential Links:
