Thread: Could it be mustard algae?
    May 2009
    Mn
    198
    I have only had a cc of .5 twice. My fc stays high if we don't use the pool and keep the cover on. We are constantly battling "silt" on the bottom of the pool. Not on the sides. Last night swimming we figured something was up cause the water felt sticky. Checked fc and cc. Fc was 5 and cc was 0.
    Checked it this morning and fc was 4.5 with cc of .5. Yes the sun was shining on the pool (cover on) but I check the pool often enough to know that the few morning hours of sun don't matter.
    Here are the results:
    Fc 4.5
    Cc .5
    Ph 7.5
    TA 250
    Ch 350
    Cya 40-50
    Temp 89
    I know I shouldn't but I did put in algaecide on Saturday. I've used it a few other weeks too when I thought we weren't going to be around to tend to the pool. - biogaurd's inhibit product.
    My fc was 8 on Sunday.
    We live about 1 mile from a gravel road and there is farmland behind us. Currently the crops are just growing so no dust from there. The water is clear. I can vacuum up the "silt". It easily brushes away and there was hardly any in the pool last night.
    Thanks
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    22,553
    Re: Could it be mustard algae?
    That's not MA. It's most likely just as you say, silt. If it was MA it'd be growing on the shady side and up on the walls.
    May 2009
    Mn
    198
    Thanks for the quick reply. No shade in my pool except for when the sun is lower than the side! I'll be thankful for the blazing sun!
    Butterfly's Avatar
    South Carolina
    10,045
    If your water feels sticky, you should do an OCLT (overnight free chlorine loss test) to rule out/in organics.
    You're done SLAMing when:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    My neighbor had "silt" looking a material that vacuumed fine. I thought it might be pollen, but it kept showing up. I did the OCLT, and measured a loss of 2.5 ppm of FC, we are shocking now and not seeing anymore "silt". You might want to try and OCLT?
