- Oct 19, 2010
- 45
Ok here is the short - so I was Haboobed, got my pool clear, then my strainer box crack, plast aid'ed that, now its working again... Ive been hitting it with lots of chlorine but unable to get my levels to rise or stay over night. I have tested and have seen no CC's also. I have 0 TC. My TA is 20?!? and my CYA well there isn't enough water in the tester to and the tube isn't long enough! the water is mostly clear to the top...
TC-0
PH-6.8
TA-20
CYA-Ungodly high!
Can you help me and tell me what I should do? do I drain this thing 60% and add new water?
I have a sand filter and the pool is 1bout 11500 gallons.
Also I have been running the aerator a lot to try and cool the pool down ->AZ
thanks much!
TC-0
PH-6.8
TA-20
CYA-Ungodly high!
thanks much!
