Thread: Trying to find filter cartridges?
    Jul 2011
    Quebec
    13
    Hi!
    I'm trying to find filter cartridges for an Intex Easy-Set 15' x 3' inflatable pool, but our local Canadian Tire retailers are all out. Does anyone have any ideas? The cartridge I need is their Type A cartridge - 4 1/8 inches wide by 8 1/8 inches high. I can order them directly from Intex, but I'm not sure yet how long they'll take to arrive as we're in Canada and Intex is based in the U.S. It's kind of urgent as we just got the pool without realizing we should have gotten a supply of filter cartridges, and they only last two weeks.
    Thank you!
    Alex
    Fast Set 15' 36" inflatable pool - 2500 gallons, cartridge filter, above-ground, filter 530 gallons per hour
    Re: Trying to find filter cartridges?
    Hi Alex, don't panic just yet! You can clean your cartridge filters and they will last alot longer. You can order some from your choice of suppliers. But in the meantime you can spray them off with a water hose (use a spray gun for better force), and then soak for a short while in a bucket of water with some dishwasher soap (not dish detergent) and then rinse again. This should hold you over for some time until your new ones arrive. I have only 3 B size cartridge filters that I have been using since May, and I keep them sparkling clean! Saves alot of money too!
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Dont order them from intex...you'll get them in October! If you can't find any locally, order them online elsewhere. Easy to find, look on ebay. Amazon or what ever is cheapest. And yes...you can wash them and re-use.
    Essential Links:
    You can use the Pleatco PC7-120 or the Unicel C4607 as a replacement.
    Support the site
    Jul 2011
    Winnipeg, Canada
    11
    Hey there. Cleaning them is a great way to save $ and it works well. I am also in the "true north" and I use the same type filter as you do. I think that you would be lucky to find them at any major outlet store now as they are all switching to winter stuff. If you are close to a pool store you might try there. Also try ebay, there are lots there.
    15'x52" Summer Escapes AGP with 1000GPH pump and side skimmer/filter system
