Thread: CC Testing
    Jul 2011
    St. Paul, MN
    244
    CC Testing
    When performing the FAS-DPD test, for the FC test I added drops of R-0871 until I thought the water turned clear. I then added five drops of R-0003 to perform the CC test. The solution turned pink, but then clear again upon adding 1 drop of R-0871, giving a CC of 0.5.
    Since I haven't had any CCs in a while, I repeated the test. This time I added one extra drop of the R-0871 (one drop past clear) during the FC test. This time, when I added the 5 drops of R-0003 the water did not turn pink, giving a CC of 0.
    I am thinking that during the first test, the solution never got completely clear during the FC test, and that's why it turned pink when adding the R-0003. Is it OK to add an extra drop of R-0871 during the FC test before performing the CC test?
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: CC Testing
    Either way...............at .5 or less you're good to go.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: CC Testing
    Since you added an extra drop of R-0871 after it turned clear, you count that as a drop when testing for CC with the R-0003. Same as if you added the R-0871 after the 5 drops of R-0003.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
