Lowering Chlorine levels
Jun 26, 2011
62
Lakewood, NJ
After testing my pool last night with a CC level greater than .5 I decided to shock my pool.
This morning I had an OCLT of 1 ppm and my pool looks crystal clear.
I don't know caused the CC level to go up.
The problem I now have is that I have FC of 30, and my family wants to swim. Is there any way that I can lower the chlorine levels? at what level would it be safe for pple to swim?
Pool stores sell what's called "after shock" which is a chlorine reducer. The problem with using these a lot is that they add sulfates to the water. But one time should not hurt. I believe the rule of thumb here is that anything below shock level is ok. I like it to be below 10 ppm, that's just me.
I'm not sure what your CYA levels are, but its considered safe to swim if the FC is at or lower than the shock level in the Chlorine/CYA chart http://www.troublefreepool.com/pool-school/chlorine_cya_chart_shock. At 30 your CYA would have to be at least 80.
If its too high you can just wait it out. Alternatively you can add chemicals (sodium thiosulfate, etc) to reduce the chlorine. Here is a post where posters discuss lowering chlorine http://www.troublefreepool.com/best-way-to-reduce-chlorine-level-t13163.html
I found chem geek's advice particularly relevant
chem geek said:
... As for lowering the chlorine level in a hurry, either in a pool or in a spa, one can use a chlorine neutralizer (sodium thiosulfate). Alternatively, you can use hydrogen peroxide (especially for the spa since the quantities are far lower) where a 3% hydrogen peroxide solution neutralizes approximately the same volume of 6% bleach. So to neutralize 10 ppm FC in 10,000 gallons, it would take around 26 cups (1.6 gallons) of 3% hydrogen peroxide in 10,000 gallons or about 1 cup in 350 gallons. You can get stronger hydrogen peroxide for the pool, though usually one just uses sodium thiosulfate instead at a rough rate of 2.6 ounces weight of sodium thiosulfate to lower 1 ppm FC in 10,000 gallons.
