Thread: Is this possible?
    Sep 2010
    Tampa, FL
    14
    Is this possible?
    Just got done shocking my pool for about 3 days. I hadn't tested PH during this time because I read on this site that PH test is unreliable at high chlorine levels. With CYA=60, I was shocking in the FC=high 20s.
    FC is now down to 10.5ppm and I tested PH expecting it to be high since I shocked with liquid chlorine.
    However, PH has gone from 7.6 down to 7.0-7.2 during shocking.
    Is this possible? I've run the test several times to be sure.
    To summarize
    FC=10.5
    CC=.5
    TC=11.0
    CYA=60
    TA=70
    PH=7.2
    CH=250
    According to pool calculator, about 3lbs of Borax should do it, but I was expecting to have to add acid.
    I did use a little chlorine neutralizer to get FC down before a play date. Not sure if that could drop the PH.
    Thanks
    Doji
    15,000 gallon outdoor in-ground plaster pool
    Sand filter flow rate 62 GPM
    3/4hp pump
    Re: Is this possible?
    What did you use to shock?
    Support the site
    Sep 2010
    Tampa, FL
    14
    Quote Originally Posted by dojiboy
    3/4hp pump
    Possible: certainly, even though it is not what I would expect.
    There are a couple of different kinds of chlorine neutralizers. Most of them are more or less PH neutral, but some lower the PH.
