Thread: HTH Chlorine Tablets -- Vacataion
    I am going on vacation for a week. I have approx a 31k gallon pool. How many tablets do I need to put in for the week? Let 2 floaters in with tablets?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Apr 2011
    Lynchburg VA
    393
    Re: HTH Chlorine Tablets -- Vacataion
    As long as your pool can handle the additional CYA I would load the floaters to the brim with pucks and bring the pool up to shock level just before I left. There is no way I would want my pool to run low on chlorine while I was away on vacation. With 2 floaters, do you have a neighbor that can drop one in for you at the half way point?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    What he said.
    Plus, unless you have an autofill, add water to get it a couple inches higher than normal, to allow for evaporation. You don't want the pump to start sucking air.
