Results 1 to 7 of 7
Thread: Is clorox harmful to the liner?
    I have a question about the closing of my pool, I used to spend $125 on a pool closing kit at a local pool supply and every spring when I took the cover off, it was a green swampy mess.
    One of my friends laughed when I was complaining about spending that kind of money and told me he uses clorox bleach, and nothing else, it costs him a total of like $20 and every spring, when he opens his pool, it may not be crystal clear, but it certainly does not look like a swamp.
    I knew I was in for a liner replacement this year, so I figured I would give it a shot and he was right, not crystal clear, but certainly could see the bottom, and was amazed.
    My question is how harmful is clorox to the liner? Since I did get a new liner this spring, not sure if I want to chance fading it, or ruining it??
    11000 gal in-ground plaster with spa.
    36 ft2 DE (using Fiberclear)
    Sta-rite 1.5 hp pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Is clorox harmful to the liner?
    Chlorox is not any more harmful than any other chlorine you put into the pool. Powdered chlorine can damage liners if it is not completely mixed into the water and the granules are allowed to sit on the bottom of the pool. As long as it is used correctly, liquid chlorine will not damage the liner. UseThe Pool Calculator or CYA/Chlorine Chart to determine how much bleach to use. Be sure to pour the bleach slowly in front of a return with the pump running. Let the pump run at least an hour after adding any chemicals, and everything should be fine.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    HOWEVER, you need to make sure there is Cyanuric Acid (CYA) in the water. There usually is, but if it's very low (well below 30 ppm) or zero, then the chlorine will be too strong.
    Sep 2009
    Greentown, IN
    914
    What they said.
    Chlorox is nothing different than the liquid chlorine they sell at the pool store.. only difference is that the chlorox is a more dilute form.
    Welcome to the forums by the way! Have a look around and I encourage you to read pool school. If you adopt the way of pool care most of us use here you will be glad you did, you will save yourself some money and headaches every season, and you will never look back!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Thanks for all the help, no I just need to figure out how many gallons of chlorox for a 40,000 gallon pool.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by johno
    These links will help:
    Chlorine CYA Chart
    Recommended Levels
    and
    Pool Calculator
    Apr 2011
    Lynchburg VA
    393
    Johno, dont forget about the CYA! Very important piece of the puzzle.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
