Results 1 to 8 of 8
Thread: Green swamp after closed for a year
    Hello swimmers,
    I have a green swamp and have read Jason's post for how to deal with it. However,
    I'm not very smart and misery loves company, so I thought I would post my progress,
    or lack thereof. Please feel free to critique or heckle anything that I post.
    Last year, I finally finished installation of my SWCG just in time to close the pool.
    Presumably, it will work if I can get the swamp under control (just in time to close it
    again).
    Here's some numbers:
    FC CYA TA PH
    8AUG2011: 0 0 120 >8.2
    Added 0 128oz liquid 10 cups dry acid
    2 cups solid in a sock mixed in water
    in the skimmer
    9AUG2011: 0 16? (<20) 100 8.2
    Questions:
    1. Should I worry about making it sparkle before I close??
    2. I imagine that I need CYA and pH under control before beginning treatment for
    algae. Any suggestions would be greatly appreciated.
    3. I have the filter on recirc until I start adding bleach (lliquid). Is that ok for now?
    Please let me know. Thanks. Mule
    Dark plaster in-ground, 25K gallons, Triton II sand fliter, Teledyne Laars Series 2 ESG heater, Polaris 280 cleaner,
    Circupool RJ45 SWCG, one skimmer doesn't work (any suggestions for snaking this or determining why it doesn't
    work?), using 12mil bubble wrap solar cover, Marquis 660 hot tub using liquid bleach.
    Re: Green swamp after closed for a year
    1) You should be able to clean it up in a week and have is sparkling in two, but you can close when it gets cold out regardless of how that goes.
    2) You absolutely want PH under control before you start shocking, but CYA doesn't need to be just right.
    3) Recirculate is fine for now. Once you start adding chlorine you will want it on filter as much as possible.
    22,548
    Your numbers are hard to read formatted horizontally like that. Here's what I got.
    8/8/11
    FC = 0
    CYA = 0
    TA = 120
    pH = 8.2
    8/9/11
    FC = 0
    CYA = 16
    TA = 100
    pH = 8.2
    You've added
    Zero FC
    128oz liquid CYA
    10 cups of dry acid
    and cups of something solid in a sock.
    Since most kits only read pH to 8.2 I'd adjust that first. Get it down to 7.2 or so.
    Once you do that then get your CYA to about 30 or so and shock it till you pass the OCLT.
    Getting it right now and closing it right now will make opening it mich easier next year.
    Maybe the data will align better this time:
    FC CYA TA pH
    8AUG2011 0 0 120 >8.2
    +128 oz liq stab +10 cups dry acid
    +2 cups solid
    9AUG 2011 0 16? (<20) 100 8.2
    I'm going to try to post it again. It removed the spaces. Mjle
    22,548
    Yes the software does that so you either have to post it like i did or add dashes.
    Thanks Bama. I did add some conditioner in a sock and hung it in the skimmer.
    I added 2 cups yesterday and 3 cups today. I guess I'm off to Leslies to buy more
    dry acid. Thanks for the quick replies. Mule
    10AUG2011 update:
    FC=0
    CYA<20 added 3 cups in a sock in the skimmer
    pH=7.5 added 5 cups solid mixed in water in a bucket and added to pool
    I may start to shock with about two hours before sunset and see if I can make any progress.
    Do you think that is a waste of time? Thanks again for all the help! Mule
    22,548
    You won't lose any FC to sunlight if you do it that way but you'll have to continue it tomorrow if you want to win.
