Results 1 to 8 of 8
Thread: Is my pool set too high?
    Jun 2011
    Michigan
    41
    So I am essentially doing the contracting of burying a Radiant Metric GT pool. I was worried about digging too deep, so I kept the depth a little high. Because of the grade of the lot, the pool is 7" above grade in the front and 20" above grade in the back. I haven't backfilled yet, but I am worried that since it is sitting that high it may not have that inground look. Did I set it too high or is this something that can be easily fixed with backfilling and grading?
    24' x 52" round Radiant Metric GT, Fully Buried.
    Re: Is my pool set too high?
    Any chance you could post a picture?
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    22,551
    It all depends on your site as to how it'll turn out.
    As Crek said, some pics will help.
    Jun 2011
    Michigan
    41
    direct front view 7" above grade.
    22,551
    If you have a big enough space to slope it, it won't look bad. Also the deck will account for some too.
    Jun 2011
    Michigan
    41
    I guess it is water under the bridge, but how would a professional have handled this. Since my yard slopes about a foot over the distance of the pool install? I guess I could have gone 3 inches deeper, but that still would have put me at 4" in front and still 17" at the rear.
    http://imageshack.us/photo/my-images...lsideview.jpg/
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I think it looks good, that dirt still has to be leveled out, you could always bring in some extra dirt which isn't that expensive. Plus, if you add a deck or patio, I think it will look great.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You need some elevation to avoid surface water running into the pool. If you are planning a deck, you'll eat up most of that 7". IIRC, the goal on ingrounds in our area is minimum 4" above grade at all points.
