Thread: Building a new pool near Houston
    I will be contracting out the construction of my new pool soon and appreciate any input from all of the knowledgable members of this forum. It will be a game style pool (3' depth on the ends and 5' in the center) in the Houston area. I am also interested in any contractors that can be recommended for hire. Thanks for any information or suggestions.
    Mar 2010
    Spring, TX
    1,082
    Re: Building a new pool near Houston
    Try these guys and see if they can help or recommend. They are located in Spring, TX.
    http://www.professionalpoolsupply.com/
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    Poolman in Tomball
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Thank you for your suggestions! I will check them out soon as I begin my project.
    Beware of installing rocks that are sandstone for waterfall or edging the pool. Sandstone wears too easily and rough edges within a few inches of waterline are algae magnets. My rock coping goes 3 inches into the water and is impossible to clean of calcium deposits or algae, and then some of the rocks are melting away slowly (small pile of sand below, or places where rock is less than grout line indicates)
    Thank you Anonapersona, those tips are greatly appreciated.
