Thread: Starburst LED Pool Light
    Has anyone tried the Starburst LED pool light. It just replaces a regular pool light.
    I am interested in buying it, but it is hard to find any reviews or ratings.
    http://www.amazon.com/STARburst-Edis.../dp/B004KOPJWG
    Dallas, TX
    12,500 Gal.
    DE filter
    In Ground
    Plaster w/ 80% Quartz
    1.5 HP Jandy Stealth ePump
    PDA Controller
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Starburst LED Pool Light
    I've never heard of it.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    That's the lowest price I've seen for an LED bulb.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    no-mas's Avatar
    Jun 2008
    FL
    405
    The light you linked to is designed for a spa; one for the pool is larger, with around 200 LEDs instead of 72. I have similar lights for my pool - bought them several years ago to replace my 500W incandescents. Red is very dim, but the other colors are pretty good. I mostly use it on white. Certainly not as impressive as an intellibrite or color logic, but I like it as a resonably priced retrofit.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
