Thread: transitioning from PS to TFP, how am I doing?
    got Taylor K-2005 today. results:
    FC 6.0 (diluted sample 1:1 with distilled H2O)
    TC 6.0
    CC 0
    CYA 45
    pH 7.4
    TA 120
    CH 260
    pool looks really sparkly, clean
    questions:
    1. I'm a little confused on the pool calculator. what is my goal for FC with CYA 45? For right now I have my SWG off over night to let FC fall and to do OCLT to make sure I'm finished with the shock I started last week.
    2. When should I raise CYA to 70? I get on PC that I need 6 lbs granular CYA.
    3. If I keep adding acid as needed when pH climbs (which it likes to with my SWG and fresh plaster) will I eventually get TA down, or do I need to use the "lowering TA method" from pool school. I don't mind adding a little acid daily to keep pH under control.
    4. I would like to run my pump less. I did not realize till I read TFP but I have been running it 24-7 since I opened the pool 2 1/2 months ago! It is a 1 hp pentair 1 speed whisperflo and I have a 30,000 gal pool. I was going to try running it from 8am to 12pm daily. Is this a good place to start?
    thank you! I'm really appreciating you TFP folks!
    30000 gallon inground gunite pool
    Intelliflo ic-60 SWG, pentair tagelus sand filter, 1.5 hp whisperflo pump, tf 100 test kit,
    2 kids(tl), 1 mini-dachshund/lab mix(t),
    Central Illinois
    Re: transitioning from PS to TFP, how am I doing?
    1) Look at the suggested FC levels section once you have entered yout current CYA level.With CYA at 45 and a SWG, FC should be between 2 and 4, or perhaps 5.
    2) Soon.
    3) Yes. Lower PH to 7.2 each time it gets to 7.8 until TA comes down to something more reasonable.
    4) I'd try something closer to 12 hours a day to start with, and then adjust from there depending on what happens.
