Results 1 to 9 of 9
Thread: Pool is becoming a money pit.
    Jezz just 5 months ago I spent just over 2 grand getting leaks fixed. I leave for vacation a few weeks ago and get back to find out I have another leak. I have been having to add water everyday just to keep the water level at the skimmer and now my deck is raising up from the pool on one side. Is their any write up's online about doing your own return pipe leak detection? I am just not in a financial position to spend another 2 grand on this thing and figure if I don't take care of it my pool is going to just get worse and worse.
    30,431
    Re: Pool is becoming a money pit.
    Can you post some pics of that area so we can see what's happening?
    I can't think of a link that would help because each pool is so specific but I'll bet you can get good advice here if we get a vuisual idea of what's happening with your pool.
    Ill get some pics of it tomorrow. Basically were the deck meets the pool its lifting.
    looks like your tile needs to be regrouted
    You obviously have some movement going on. I think if it is re-grouted it will crack. You should clean the entire space by removing the existing materials from the joint. Fill the bottom of the void with backer rod and caulk the joint with a high quality polyurethane sealant. Backer rod and sealant can be found at Lowes or Home Depot.
    Quote Originally Posted by slambrecht
    Thanks for the reply. I am not familiar with backer rod? What exactly is it?
    Does any one have any advice on finding leaks on the return pipes? I am pretty sure I have a leak in one and need to find it. I just can not afford to pay a company to come out again and fix it. I am losing about 4 inchs or more of water a day.
    Also is their a good website for tile replacement stuff online. That is another project I really need to start on with this pool also.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Backer rod can be an extruded foam rod.
    I've seen some videos where they use a dye to find the leaks check you tube.
    Jul 2007
    Northern NJ
    299
    What kind of warranty/guarantee did you get for the leak repairs that were originally done? Is there no way that one of the leaks previously fixed has started leaking again?
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
