Thread: Plumbing - 1.5" vs 2"
    I am in the end stages of PB selection and coming to the fine details. This is for an 18x36 mountain pond, about 25k gallons. One PB is using one skimmer and 1.5" plumbing with 1HP super pump. The other has standard 2" plumbing with two skimmers and a 2HP super pump. Both same pool? Either right or wrong?
    Thanks!
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    Re: Plumbing - 1.5" vs 2"
    2" plumbing will give you higher turnover, with higher turnover rates; which is better for filtration. Additionally, two skimmers gives you more debris removal. I would recommend the 2" setup. Here is a table you may find helpful, describing flow rates:
    http://flexpvc.com/WaterFlowBasedOnPipeSize.shtml And here is a page explaining turnover and turnover rates:
    http://ppoa.org/?page_id=463 Of course, safety covers over two drains would be necessary.
    Disclosure: I have 1.5" plumbing with 1 skimmer; it's adequate, but I would prefer a 2" with 2 skimmer setup for the above named reasons.
    Tom
    20k gal. 36' In ground Med. Blue plaster, two-speed EcoPump EP6, Pentair 3.14 sq. Ft. Sand w/zeosand, Spectralight SL 500, RayPak 2100 heater, Polaris 360,GE Timer 15087, Borates 80 ppm.
    PB compromise was two skimmers w/ 1.5" plumbing and 1HP hayward superpump. Will this be sufficient?
    Thanks!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Any water features (fountains, waterfalls, etc) with the pool? 2 hp is much too big, unless you have a spa or a big waterfall. 2" is better, and there's no reason why any pool builder should resist it.
    If you don't have any water features, I would suggest a 2-speed 1 hp pump.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Quote Originally Posted by Melt In The Sun
    Ditto...2" plumbing and any pump over 1HP is overkill, unless there are water features. The 2sp 1hp with 2"plumbing would allow for energy savings and an efficient set-up.
