Thread: Look at all the RUST!
    OK, purchased home with 27ft above ground pool. Pool was put installed in 1997. Have been using pool all last summer and upon opening it this summer, we had to clean a bunch of rust from the bottom. Noticed the rust on what I believe are the rails (please correct as necessary as I am not completely familiar with pool terminology). It is all along the rails and as bad as the pictures get all along the rails.
    Are these replaceable? Is a new pool in order? The pool functions properly, as does the new pump and filter, everything works wonderfully. There is just a lot a rust everywhere and I fear it is not only corrupting the pool water but, and hopefully not, damaging the pool itself beyond repair.
    The old owners weren't much of the fix it with new parts kinda people, duck tape was their friend. It seems they may have let this go a little too long.
    Any advice?
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Re: Look at all the RUST!
    Where are you located? It looks like salt air rust to me. Do you know who made the pool?
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    I am currently looking into who the manufacturer is (need to find the manual that came with the house!). I am in the middle of Kentucky, so I wouldn't think salt air is the is the problem. A serious lack of maintenance on the previous owner's part is still my bet!
    Bump
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    That rust is bad... I'd be stumped too. Wire brushing it and painting won't do any good. Anything that rusty needs to be replaced IMO. Did you ever find out who the mfr. is and do they have parts you can replace? Those screws probably won't even be un-screwable.
    The joints look dangerous. Is there a joint cover that is supposed to be there?
    I know, nothing helpful in my post but maybe bumping again will get someone who knows something to notice.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
