Thread: rinse after backwashing?
    hawkeye's Avatar
    davenport,iowa
    118
    i only backwash once a week...should i switch filter head to rinse after a backwash?
    i always wondered and keep forgeting to ask.....thanks mike
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: rinse after backwashing?
    I would, it prevents a small amount of sand/stuff up in the valve, from the backwashing, from going back into the pool.
    By the way...go ISU :P
    Quote Originally Posted by hawkeye
    How many psi does your pressure rise in a week? Or do you just routinely backwash?
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    22,543
    You only need to backwash when the pressure rises about 25% above the normal clean pressure. I wouldn't backwash every week unless it required it. And yes, you should rinse the filter a minute or two after a backwash.
