Thread: Best buy for Shock Product
    Just wondering if anyone can suggest what is the best buy for Shock products?
    Jovian, Pool owner since 2011
    Specs: 30k Gallons, Sand Filter, IG, Vinyl, Filter: Hayward S244T, Pump: Hayward 1.5 HP SP2610X15
    Re: Best buy for Shock Product
    bleach?
    24' AGP sandstone,12,000 gal , cricupool rj30 SWG,fas-dpd test kit. BBB
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yes, bleach or liquid chlorine (both have Sodium Hypochorite, but at different concentrations) is best in the opinion of most on this board. We consider shock to be a process and not a product. See: http://www.troublefreepool.com/pool-...king_your_pool and let us know if you need any help.
    Aug 2010
    Boston, MA
    176
    In particular, the liquid forms of chlorine are superior because they don't add extra stuff to your water and thereby cause other problems later. Anything solid should only be used if you know your CH/CYA levels and want to raise them along with providing chlorine.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    OTOH, if you can handle or need the extra calcium, cal-hypo is pretty cheap in the 90 lb buckets. I would never buy it in the 1 lb packets, too pricey. It keeps well in the heat and so is a good thing to have on hand for infrequent shocking. But only if your CH does not tend to run high. 64 oz will take me to shock level (from 3 to 18 FC) and raise CH by 11 ppm. For a serious problem where a lot of FC was needed over a long time, I'd still use primarily bleach, but cal-hypo 73% from Leslie's Power Powder Pro is great for a short duration thing.
    Thank you all for the comments. Yes, I should remember shocking is not a product, but a process. I just want to confirm what the best buy product to do the process of shocking is, and I gathered that liquid bleech is still the best (economical too).
