Thread: Intex pump question
    Intex pump question
    Hello im new to pools and i know this is completly off subject but i have an intex 637r (1000 gph) pump and was wondering if it would be possible to leave the filter out and hook it to a sand filter? I have a muskin sand filter not sure of model number or size though any help would be greatly appreciated thank you
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex pump question
    I have done this with very poor results. Pressure runs very low and there is no way to really backwash. In a pinch, it might get you by for a few days, I would think it is better than no filter, but I am not sure it was better than the filter in the pump.
    Thanks for the advice another question though is it possible to run a sand filter half full of sand
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You really need to put in the recommended amount.
    Thanks for the answers
    Aug 2011
    Virginia Beach
    295
    I upgraded to a sand filter/new pump on ours and don't regret it for a second. I've not bought any more cartridges, and backwashing is easier than re-priming the intex pump. I still use the original one sometimes to help circulate the water or get chemicals dispersed more quickly.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
