Thread: Help Code 194 AAand 125
    Jandy 1400 - preducing 125 and 194.
    Oct 2010
    Georgia
    317
    Re: Help Code 194 AAand 125
    These codes indicate low cell current and high cell voltage.
    These codes could indicate a dirty cell or a cell that needs to be replaced.
    Clean the cell per the manufacturers instructions to see if the trouble codes clear.
    If the codes are still present after a thorough cleaning, then it may be time for a new cell.
    Is there a pool store nearby that can test the cell for you?
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Any idea about how much a cell will run? I cleaned it this weekend
    May 2011
    Sacramento, Ca
    64
    Quote Originally Posted by weidemeyer
    I bought a replacement cell/sensor/cord online at Poolsupplyworld for $489 plus tax. It got here (california) fast and is working great. I did have to re-plumb my fittings because the new 3 port cell has different couplers than my old 2 port cell.
    http://www.poolsupplyworld.com/pools...s/R0452400.htm
    30,000 gallon in ground pool, Jandy 1400 SWG, Jandy valves and controls, Sta rite cartridge filter, Just added solar panels and Starite Inellipro variable speed pump
    I spent a lot of money on drag racing, good whiskey, and expensive cigars. The rest of my money I just wasted.
    Cell had to be replaced. Thankfull it was covered by Jandy.
