Thread: Confused about readings - too much or just rite?
    I have an Aquarite Plus SWG that indicates 2800-3400 salt level is optimal. We added 880 pounds of salt on 13 July for our 24000 gal pool. Salt level readings were 2800 the first few days and now fluctuating between 4100 and 4300 (?). The salt strips test show 3680 consistently. The water does taste a bit salty and I have just noticed some white powdery stuff on the metal of the pool brush; hubby tasted and does not think its salt. Watery is super clear and sparkly. ETA: No "salt too high" warning lights are on the control panel
    At present, we have
    FC 8
    CC 0
    TC 8
    pH 7.2 (just added MA last night so expect this to bounce back up very soon)
    T/A 130 (cannot get this below 110)
    CH 320
    CYA about 60
    Temp 84F
    We are coming off a shock level at 20 so this is why FC is so high. Should we keep it there? Also, the SWG is set at 35% now. We run it during the daytime.
    At this point we are wondering if we should dump and refill some of the water or let it be.
    Thanks for you insight!
    21x40 - 28000 gal Kidney w/swimout, bench, Aqua Comfort Heat Pump, AquaRite Plus SWG, LED, White plaster/blue tiling, Cartridge Filter, 1hp pump, Polaris 380
    22,539
    Re: Confused about readings - too much or just rite?
    880 lbs of salt would have raised your salt by 4400 ppm. I'd drain some out to get to about 3400 according to the swcg.
    24' x 52" Round AGP. 2hp/╝hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Hey Dave, are ya ready for a RV/pool swap yet ? LOL
    So according to the PoolCalc. we would need to drain 17% of the pool. Is there faith that the Aquarite Plus reading is correct? How can it go from 4300 to 4100 and bounce around so much? I wonder why the SWG is not throwing any warnings either. We are dreading having to drain that much but of course will do so. Any chance that 17% loss will result in a float of some sort - kinda high water table here.
    I was thinking we drain and fill at the same time....can we do that if we attach a hose to the extra faucet on the equip pad? Drain on one end fill on the other. How soon will the SWG reflect the difference?
    Thanks!
    22,539
    Guess I'll have to hang on to it a while yet. Don't know where I'd put a second pool
    Salt readings ┬▒400 are considered to be the same. What I'd suggest is to drain a little (maybe 5 or 6%) and then let it run a while. If the swcg is happy at that level and is generating I'd probably leave it alone this year. You're probably going to lose some over the winter and next year will be fine.
