Thread: hayward pool pump troubleshooting with hose kinking
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Hi all,
    I really enjoy reading in this board. I'm learning so much. As you can tell, I'm a newbie and I have a question. We bought a new pump for our 14 x 42 summer escapes metal frame AGP since the one that came with the pool sputtered and died.
    We bought a new Hayward easy clear full flo element filter pump with 1 hp. It is up and running, but we noticed that the intake hose is kinking or bending in half. It reduces the pressure of the pump to about zero. If we hold the hose up to remove the kink, the pressure goes up. We thought about removing the kink by extending/holding up the hose by tying it with cable ties to the pool. Is the kinking of the hose a serious problem, like the pump is clogged or too much power for the size of the pool, or is it due to the the hose not having enough room to stretch out from the pool to the pump.
    Also, we are getting tiny bubbles coming out of the return spout. Is that a good or bad sign.
    Thanks so much in advance for any help.
    Liz
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit - Swimmers: Twins (Boy/Girl) 16 yrs old
    Jan 2010
    Randleman,NC
    620
    Re: hayward pool pump troubleshooting with hose kinking
    Yes,I have found that some strap's alway's help..But if you we take some brick's or fix a flat area that the hose can lay on&be supported will alway's help..Let your mind work for you..Haave a neighbor take a couple 4 by 4rs &put in the ground&run some 2by 4rs to let the hose lay on to support..Used some nail's on the side of hose to keep it in one spot..You have to remember you have a AGP & you have to make thing's work ..inground pool's everything is permanent..
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Thanks for the fast reply! We will try to build a little shelf to support the hose. Great idea.
    Do you know what might be causing the bubbles in the return? Is that a bad or good thing.
    Thanks again,
    Liz
    Jan 2010
    Randleman,NC
    620
    Bubblies are sign's of air getting into the system..It maybe because the hose is kink'd enough it is creating air pocket's in the hose..Not sure there are more people that would know more..I would def. get the hose supported..I have some brick's under my inlet hose&have a heavy duty strap holding up the return..Also I went to 3 ft hose's last year..That has help'd alot..You prob can get away with just 2by 4rs..Good Luck
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Thanks again. Will look into supporting the hose and seeing where the air is coming from.
    Have a great Sunday!
    L.
    Jan 2010
    Randleman,NC
    620
    You too&good luck...
