Thread: Stain ID
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Stain ID
    Have started to have staining in my 2 yr old SWG pool (Sunstone finish). Stains are either dime sized or 1-2 inch streaks. Have tried both scrubbing with the lemon/Vit C tab and with a chlorine puck. Strangely have not noticed much difference with either. Pic is attached.
    FC - 5 ppm
    CYA - 45 (but raising to 80 today)
    ph - 7.5
    Any ideas if metallic or organic stain? Then course forward?
    Thanks
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    South Central NJ
    3,192
    Re: Stain ID
    Those really look like iron. Try the Vitamin C again and let them sit a little longer, with the system off to reduce water's movement.
    Scott
    Owner of - PoolGuyNJ LLC
