Thread: New Compupool SWG Output % LCD Indications
    May 2008
    SC
    47
    Realized last week that output of my Zodiak LM2 was quite limited because two chunks of the cell where missing when viewed from the bottom. Cheapest replacement I could find was about 350. Figured 450 for a whole new compupool would be worth it.
    Swap was pretty straight forward wiring was simple swap, and the cell spacing was the same. Just cut off the old fittings, glued on 1 /12 to 2" converter which fits the outer part of the new fittings.
    Great to actually see huge amount of gas pouring out of the thing. I noticed that the incremental LCD output lights have a lag with respect to selected output settings. Yesterday the unit was at 100% for a while and producing nicely. I set the unit down to 70%. Today, FC was down to 3 and I'd like it around 4.
    So I noticed the output lcd only had one bar. Even when I adjust the output to 100%, I only get one bar. Ideas?
    Pool: 10K Gallon Fiberglass w/ SWG and cart filter.
    Spa: 400G D1 w/ Ozone, Vision (Silver Ion).
    May 2008
    SC
    47
    Re: New Compupool SWG Output % LCD Indications
    FC Down to 2ppm, and stuck one bar for output? So why won't this thing kick back up toward 100%? My salt is about 3600 and unit reads anywhere from 3600 to 5000. Don't really understand the units cycles of taking measurements and switching polarity.
    Jul 2007
    Brisbane, Australia
    874
    assuming you measured your salt with strips...
    put some chlorine in manually and wait until tomorrow to see if the unit will go back to full output after the unit reverses polarity
    if it keeps going to one bar on polarity switch to one side it usually indicates a fault in the unit circuitry, or one side of the cell being bad (or having non-reverse polarity cell on reverse polarity system but not sure if it's possible with CompuPool)
    a manual should specify how often it does polarity switch, so you can check then
    May 2008
    SC
    47
    Just took salt strip measurement... 4000 ppm. Also figured out how to switch polarity on comupool (hold up arrow for 5 sec). It's internal readings are as follows:
    Polarity 1 3900
    Polarity 2 3200
    Temp 102 (83 actual)
    I as contemplating the calibration feature when unit was reading around 5000ppm, thinking that may have throttled the unit somehow. Think I'll let it stay stock for now, and maybe adjust polarity 2 if it continues to read low.
    FC was 1.5. Will add bleach to bring back up to 4 as you suggested. Will that somehow help the unit output more?
    Other numbers as follows:
    PH 7.8
    FC 1.5
    CC 0
    TA 60
    CYA 35
    Borate 50
    Salt 4000
    CH 190
    Temp 83
    Anything there that would inhibit SWG output? Plan is to get CYA back to 75 (per pool calc vs compupool rec of 30-60) and TA back up to 70 (vs compupool rec of 100-120).
    Jul 2007
    Brisbane, Australia
    874
    well nothing apart from salt level/temperature should inhibit the output bar.
    it's possible that algae bloom consumes a lot of chlorine, but the unit should still be producing at 100%
    if that's not the case you might need to ring support and ask them
    May 2008
    SC
    47
    Finally got a call back from support. They said they are sending a new LCD PCB in 7-10 days (but it shouldn't take that long)! Good support, but kind of a bummer that the unit worked for one day?
    Gonna take inards apart and make sure nothing is loose in the mean time... and buy more bleach
