Results 1 to 11 of 11
Thread: Can I use an old heat pump from my house for pool?
    I have an old 3.5 ton rheem heat pump (outside and inside units) that I removed from my house. Any way that I can convert this and use it to cool my pool in the summer (water is 95 degrees now) and heat it in the winter? I have searched and not really come across anything yet. Some way that I can have pool water running across the coils instead of air like it was originally intended?
    31,000G IG vinyl 20X40 True L. Hayward 1.5 superpump, Autopilot Pool Pilot Digital SWG, Hayward Model S244T 300lb sand filter, TF100 kit
    Re: Can I use an old heat pump from my house for pool?
    I am not going to take a stab at the heat pump. On cooling in the summer, I have a hose bibb on the pressure side of my pump and if I hook a hose to it and just shoot a full stream of water into the pool it will knock of several degrees in maybe 10 min. That is a lot cheaper and easier than running a heat pump or chiller. I'll leave the heat pump conversion to the more adventurous among us.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    It may not even be cost effective to try to do what I was thinking. Just had extra equipment around and was brainstorming.
    If the coils are copper with aluminum fins, which most are, a bunch of chlorinated salt water is going to be **** on them.
    1 1/2 HP Challenger
    Located in NOLA
    I found these and thought there may be a way to integrate them with the old unit I have.
    http://www.poolheatpumps.com/titaniu...-exchanger.htm
    Call them up and ask them if they are compatible.
    1 1/2 HP Challenger
    Located in NOLA
    Just got an email back from them. He stated that the 3.5 ton unit I have is way to small for my pool but it could be integrated. He said I'd need at least a 5.5 ton.
    Quote Originally Posted by jsw5620
    Wow, takes 5 1/2 tons, that's a lot of heat pump. The power company would love you.
    1 1/2 HP Challenger
    Located in NOLA
    With an average power bill of over $500 per month in the summer, they already love me
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Lots of folks want to look at alternative means of moving heat into or out of their pools, and while it's good that they are thinking about it, most really don't realize how massive a heat load a swimming pool really is. Lots of BTU potential in that thar pool.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Wow$$$ Where are you at? I pay about $0.26/Kwh here, and the bill each month is around $375.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
