Results 1 to 7 of 7
Thread: jastu23 from Allen, TX. Hello and Thank you!
    Aug 2011
    McKinney, TX
    3
    I've been happily skimming your site (sorry for the bad pun) and have went from a clear pool with tons of CYA (Thanks previous owner and local pool store) to an even clearer pool with proper levels maintained using your guidance and the BBB method! It seem more clear and sparkly when you know what's going in, and why, and for a lot less money! Hopefully, my signature updated correctly, but thanks to this great site, and common sense recommendations, my pool is great looking and currently at the following levels:
    FC - 3
    CC - 0
    pH - 7.5
    TA - 70
    CH - 300
    CYA - 40
    About a month ago, I drained my pool down to 20% (The Pool Calculator is fantastic, by the way). Prior to that, I fought high CYA levels two years in a row. Since then, I used a few trichlor tabs (5 to be exact) to get CYA to 40 and, because I travel a lot, will use those sparingly, and allow that level to rise slightly, and within reason, over the summer. In the meantime, it's store brand bleach!
    Since I haven't needed to post specifically, I wanted to drop a line here, thanking all those who contributed in the past. I'll soon be a supporter, and may have some questions as I contemplate converting to SWG. Also, I will be searching or asking about best ways to get rid of what looks like calcium spots on the tile near my water line. For now, I just wanted to introduce myself, and give you all a great big thanks!!
    P.S. my co-worker is a brand new pool owner who, after having his pool builder sell them $50-$100 bucks of "****" per week, is a new convert to BBB.
    18k gal IG plaster, hayward DE6020 60sqft. 120gpm, pentair vs3050 3hp, polaris 280 with pb4-60 3/4hp booster pump, intermatic pf1222t timer, rainbow lifeguard 320 chlorinator (not used any more!)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: jastu23 from Allen, TX. Hello and Thank you!
    Welcome! Just be sure and not let all that rainwater you're getting mess up your chemical balance
    Aug 2011
    McKinney, TX
    3
    Thanks for the greetings! And for throwing superstition out the window. It's been so long, I can't remember what a rain shower looks like any more. Hope you're faring better in your part of Texas!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Wow! You joined TFP, support the site w/platinum membership and you already have a BBB convert!
    You're done SLAMing when:
    Aug 2011
    McKinney, TX
    3
    Thanks for the vote of confidence! Actually, I've been using the site for a while, and once I took the leap and began practicing the methods, it was as fast and effective as everyone says. As far as the membership, it seems like it was free when compared to all the money I've already saved in those chemicals I once thought could only be bought at a pool store.
    For the others like me, I can attest to the fact that TFP really does cover everything. And it works wonderfully! Actually, explaining it to others who make that "you're putting bleach in your pool?!?!" face is almost as much fun.
    nutjob's Avatar
    May 2011
    Dallas
    109
    Hey there neighbor! Glad to see I'm not the only Allenite who's taken control of his own pool's destiny.
    Now if I could get the water temp back below 90...
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
